0 Members and 1 Guest are viewing this topic. Read 14096 times.
OK I have a question about a redo of my listening room. 20 feet wide 30 feet long. Isolation is not an issue as my room is about the garage. What benefit would double sheet rock provide me in this situation? Green Glue? The channel system mentioned earlier? I was thinking of framing out the corners like a triangle(3' from either wall) to remove resonant corners. Would this be a worthwhile option?
Quote from: bpape on 29 Oct 2009, 08:36 pmQuote from: rajacat on 29 Oct 2009, 05:59 pmInstead of using Green Glue why not use ordinary adhesive silicon caulk? Who knows Green Glue might just be ordinary adhesive caulk colored green but with a price surcharge. Is there a secret ingredient or what? Seems to me the point of the adhesive is to provide a flexible elastic layer so just about any sticky rubbery layer would do the job. I've found that many products are just relabeled and marketed for a premium. A case in point are the neoprene/cork footers marketed by Mapleshade and found on Audiogon by other sellers. The same footers are sold by soundproofing.com and others at way (multiples!) lower prices. -RoySure you can do that - but it's not going to perform anywhere near like Green Glue. BryanBryan, Is it based on your experience or do you know of anyone that has directly compared Green glue to other glues? Or some measurements of the viscosity or other significant attributes of Green glue in order to base a comparison? Why are you sure its so much better?Thanks for the insights...-Tony
Quote from: Curly Woods on 29 Oct 2009, 10:15 pmOK I have a question about a redo of my listening room. 20 feet wide 30 feet long. Isolation is not an issue as my room is about the garage. What benefit would double sheet rock provide me in this situation? Green Glue? The channel system mentioned earlier? I was thinking of framing out the corners like a triangle(3' from either wall) to remove resonant corners. Would this be a worthwhile option?No. Fill them with triangles of 703 floor to ceiling 24 inches at the face to the room. 8 pieces per sheet. If you frame them and drywall them they you haven't trapped any bass and you're back to square one. If you don't need to keep sound from bugging others outside the room then you don't need to redo your room unless of course you are on a busy street and the noise is coming in!
With great "bones" you'll be in the ideal position to start treating the room with absorption/diffusion.
Get Floyd Toole's book. Turns out room dimensions are not all that critical and that a double layer of drywall will probably exacerbate problems with bass.dave
Quote from: planet10 on 30 Oct 2009, 03:50 amGet Floyd Toole's book. Turns out room dimensions are not all that critical and that a double layer of drywall will probably exacerbate problems with bass.daveIt's a double edged sword.Lower noise floor - goodLower the resonant frequency of the walls - goodLonger decay times above the resonant frequency prior to treatment - not so good.Bryan
I suppose that the cost of GG, when looking the whole project, is a small price to pay even if it's just green colored premium adhesive caulk. At $7/tube it's really not much more expensive than the 4 or 5 dollars for a quality alternative.
Supposedly, you only need to mud and tape the outer layer. The inner layer, you can just fill any seams with acoustic caulking.
