0 Members and 1 Guest are viewing this topic. Read 23158 times.
I also had to subject KShep to the multi-channel.
Trilok Gurtu is awesome...
I'll probably stick with that for now.
vintagebob will be visiting my home this Saturday. So you should be looking for his impressions of my setup. I just want to put some pressure on both of us aaI'm borrowing a Luxman L-505u integrated amp to try in my system over the weekend so I will post my impressions. I hope you don't mind if I post this in the Salk thread...I still consider myself part of the family.
Thanks for the update. How did the Revel's compare to your HT2-TL's? Since they are in a different room and a different system, I think you couldn't make definitive comparisons, but it would be nice to hear your impressions.Thanks ahead of time.Bob
I will comment on the process I went through with my STs. I was able to take my STs to my favorite audio shop and do a side by side comparison. Having the opportunity to hear the STs then the Revels then the STs was valuable. What the SongTowers do well is midrange without a doubt the best I've heard. Better than the Revels, but for me the other characteristics are more appealing. I love the STs but they are lacking in the low frequency department. The difference is 42Hz to 32Hz for the Revels. The HT2-TLs are IMO a step above the STs. I don't feel comfortable comparing my speakers directly with the HT2-TLs.
How does the Halo A21 work single ended with your system? How is the A21? Is it more of a full sounding amp or on the leaner side. Your feedback would be most appreciated. Music Lover
