EAC and FLAC -- short songs
0 Members and 1 Guest are viewing this topic. Read 1193 times.
ctviggen
« on: 26 Oct 2009, 09:13 pm »
Anyone have problems with the periodic short song with EAC and FLAC?  For instance, EAC appears to have copied the song "In the End" from the album "Hybrid Theory" from Linkin Park as being 2:10 long, when the song is really 3:36 long.  The song simply cuts off in the middle of playing, and then the next song starts.
Anyone have this problem or know why it might happen?
JDUBS
Re: EAC and FLAC -- short songs
« Reply #1 on: 26 Oct 2009, 10:28 pm »
What did accuraterip say?
-Jim
firedog
« Reply #2 on: 7 Nov 2009, 05:25 pm »
I had a similar problem once - it was either a bad EAC file or a bad flac codec, I don't remember which.
Try downloading fresh versions of EAC and flac codec and do clean install.
