COMING SOON - ONIX DAC25 Upsampling DAC
John Casler
« on: 22 Oct 2009, 08:37 pm »
Just received the following announcment about a NEW ONIX DAC: aa
ONIX DAC25 Upsampling DAC Decoder:
Features:
1. Use 24bit/192KHz high precision DAC chip
2. Use asynchronous sampling chip to raising frequency at 192KHz with lower jitter
3. High precision clock system, it has Reclock function and reduce error code efficiently
4. USB input connect to the PC and realize the hi-fi sound through PC
5. Digital input plus pulse transformer as a good separation
6. Analog balance output
7. Headphone amplifier monitor
Specifications:
1. Dynamic range: (24bit) > 120dB
2. Signal noise rate: > 112dB(RCA); > 125dB(XLR)
3. THD+N: < 0.001%(20Hz-20KHz)
4. Output amplitude: 2VRMS
Main materials:
1. PCM2704 as USB sound card chip
2. PCM1792 24bit/192KHz DAC chip
3. SRC4192 upsamping chip
4. 3pcs OPA2134 op-amps
5. CS8416 digital receiver chip
6. R style transformer
This is hot off the presses, and we dealers don't even have pricing as of yet. :drool:
srb
Re: COMING SOON - ONIX DAC25 Upsampling DAC
« Reply #1 on: 22 Oct 2009, 08:52 pm »
It is a very nice looking unit.
Unfortunately, for those of us that want to connect to a computer with USB and play 24/96 high resolution files, I believe the PCM2704 limits that USB connection to 16/48.
woofersus
  • Authorized Dealer: Melody & Angel City Audio
    • East Street Audio
« Reply #2 on: 22 Oct 2009, 09:41 pm »
Excited to be offering this soon for sure!  I'm pretty geeked about getting ahold of a demo unit, for that matter...
DWayland
« Reply #3 on: 22 Oct 2009, 10:25 pm »
Yip, me too!
DWayland
« Reply #4 on: 23 Oct 2009, 06:43 pm »
Pic of the back and side:
DWayland
« Reply #5 on: 26 Oct 2009, 10:36 am »
Pricing is as follows...
$630.00
DWayland
It's here! ONIX DAC25 Upsampling DAC
« Reply #6 on: 17 Jan 2010, 06:34 pm »
I took some pictures of the new DAC-25 and placed a CD in the photo for scale.  It's surprising just how large it is.  Same depth as most other components, but about 1/2 as wide.
Below is the link to a slideshow, but I have placed a few shots here as well.
http://www.flickr.com/photos/dwayland/sets/72157623104293877/show/
Jon L
« Reply #7 on: 17 Jan 2010, 07:30 pm »
Hey, John, are you sure there isn't a 6922 tube in there?  It sure looks similar to another famous DAC with same specs, but that DAC has a 6922 in there  :eyebrows:
John Casler
« Reply #8 on: 17 Jan 2010, 07:40 pm »
Hi Jon.  It appears to be "tubeless", but if it is any consolation, some might describe the sonic as tubelike (as in lacking edginess and digititis) :green:
Jon L
« Reply #9 on: 18 Jan 2010, 04:23 am »
No worries.  I generally don't like tubes in my source most of the time  :green:
angelo
« Reply #10 on: 18 Jan 2010, 06:23 am »
hi onix dealers.  is this already available?
is it optimized for either high or low impedance phones? does the volume knob also controls the analog (se/bal) outs?
hi Jon L,
w/c similar DAC w/ tube were you referring to?
thanks,
woofersus
    • East Street Audio
« Reply #11 on: 19 Jan 2010, 03:58 am »
The Onix DAC-25 is available.  For a specific lead time you should contact the dealer whose territory you are in.  We've tested it with both high and low impedance headphones and both worked fine. (specifically 300ohm Sennheiser HD600's and 80ohm Beyerdynamic DT770 pro's)
The "similar" DAC that was referenced above is the Music Hall DAC 25.2.  There are certain similarities due to price point (many DACs in that price range have similar features) but they are not the same product.  They both use the Burr Brown PCM179x converters, but the Music Hall has a tube buffered output, while the Onix is all solid state, and the Onix has a Cirrus Logic spdif receiver/buffer to improve the signal level pre-conversion.
« Last Edit: 1 Feb 2010, 04:52 am by woofersus »
doug s.
  • makin' music
« Reply #12 on: 8 Feb 2011, 08:58 am »
ya, i know - dredging up an old thread...   :o
everywhere i see this dac, it says it has:
someone please explain this pic; it clearly shows four:
thanks,
doug s.
sandbagger
« Reply #13 on: 9 Feb 2011, 11:56 pm »
As an onix dealer, and from past experiences with the manuals and catalogs, I am betting that is a mistake.   It sure looks from what I am seeing that there are 4 there and it looks like 2 per channel.  It would not be the first time I have seen this.
kevin
