But, with that being said the DAC is not a preamp, it is a DAC with a volume control. You can get away with possibly running tube amps directly, but Solid State amps we do not recommend. The DAC is not meant to replace a preamp and definetely not for SS amps direct.
You really need a decent preamp for great, holographic sound. Remember, this is a dac that just happens to have a volume control, probably for convenience. It is not a preamp circuit, per se.
Impedance matching aside, and noting that I'm running a purist system with only stepped attenuators connected in the back of my solid state monoblocks, what are the disadvantages of not having a pre-amp following the EE DAC?
Conversely, if a pre-amp is so vital, why have a volume control on a (in the greater scheme of things) high-end product?
And seriously, other than being a tube fan, why wouldn't you recommend following the EE DAC with a solid state amp?
Note that with these comments I'm quickly going cold on this DAC.
