0 Members and 1 Guest are viewing this topic. Read 29729 times.
I appreciate the help. I'm really impressed by the nature and helpfullness of responses in this forum. It reminds me a lot of the forum on carsound about 7-8 years ago when it was active. Changing topics, Jim sent me an email giving me the rough locations of a few owners nearby, and asked if I'd like him to set up an audition for me. The closest one is 2 hours away and has a set of songtowers. I'm beginning to think I'll just take advantage of the 30 day return policy. I can't think of a better audition than one in my home with my own equipment. I plan to get standard finish cabinents, so I don't think refund or resell for Jim will be difficult if the Salks aren't what I'm looking for.Here's what I think I'll get. Open for suggestions on amps and preamps(with HDMI input) that will keep the cost of of speakers, amp, and preamp, around $6000.Speakers - Salk HT2 - TLAmp - Emotiva XPA - 2Pre amp - Possibly an onkyo 886 on the outlaw audio website ($1500 is more than i'd like to spend). Another option would be an onkyo 876 from shop onkyo (roughly $1000, but would allow me to power center and surrounds while i save for another amp). 3rd option would be an integra 40.1 (roughly $1200)
Since this will be a 2-channel system first, developing into a HT down the road, why not get a 2-channel preamp with Home Theater Bypass, then a receiver later when you get the center and rears? This way you'll get the best of both worlds. The HT bypass allows your outboard amp to be used for both the preamp and the amp, thus your speakers can stay plugged into only the amp, even though they are being used for HT and music. Using this method you wouldn't have to use your receiver's main speaker terminals. In my setup, I use an Emotiva amp to power the main speakers, but the receiver to power the center channel and rears. It works quite nicely. And most HT bypasses work even when the preamp is off, which is quite convenient. I agree with K Shep - if you can build a subwoofer you can build room treatments. They will help immensely!Speaking of subs, the reason I mentioned one is because yes, speakers as nice as the HT2 TL's do provide amazing bass, but the problem lies with the room. Generally the best spot to place the speakers in order to achieve a wide sound stage and pinpoint imaging is not the best spot for in-room bass response. Unless you have a full range EQ which many people scoff at), crossing over to a subwoofer allows you to use the subwoofer to find the best in-room bass response (it can be separately placed where it sounds best). This is another one of those "best of both worlds" scenarios I mentioned above. However, I do understand that some guys will want to stay strictly "2-channel," and that's cool. Do what you need to do, but weigh in all the options first. Amps:Parasound 2250Parasound A21AVA Insight 440McCormack (used)Odyssey AudioWyred4SoundPreamps:Parasound 2100Parasound P7AVA InsightWyred4SoundEnjoy the hunt; sometimes it's the part that is the most fun.
What is the advantage of that over using the preamp outputs of a high end receiver out to an amp to power the mains?
Quote from: coke on 21 Oct 2009, 10:44 pmWhat is the advantage of that over using the preamp outputs of a high end receiver out to an amp to power the mains?In short, sound quality; better sound quality. It's subjective so you'd have to try it yourself (by listening), but separates sound better than receivers. There is no decoding or processing circuitry. With separates you have individual/separate power supplies, thus less heat. Separate enclosures also isolate the low-level audio signals of the tuner and preamp from the large magnetic fields of the power amp (got that tidbit from an A/V mag). All of these contribute to better sound quality, IMO. Basically a receiver is everything shoved into one enclosure, but you don't need all that stuff for true 2-channel (or 2.1, like I have. Even I get flack for buying a preamp that a subwoofer output, as it adds processing circuitry). I never believed preamps/amp combos sounded better than high end receivers until I actually compared. The different was not subtle. The sound stage grew a lot wider, gaining depth along with width. And imaging - wow...big difference! Imaging went from reserved and unimpressive to pinpoint and precise. Sometimes I think my rears speakers are on, but they aren't. Anyway, YMMV, but definitely listen to both and compare. I was a skeptic, but I sure am glad I tried it out.
Quote from: Nuance on 22 Oct 2009, 12:54 amQuote from: coke on 21 Oct 2009, 10:44 pmWhat is the advantage of that over using the preamp outputs of a high end receiver out to an amp to power the mains?In short, sound quality; better sound quality. It's subjective so you'd have to try it yourself (by listening), but separates sound better than receivers. There is no decoding or processing circuitry. With separates you have individual/separate power supplies, thus less heat. Separate enclosures also isolate the low-level audio signals of the tuner and preamp from the large magnetic fields of the power amp (got that tidbit from an A/V mag). All of these contribute to better sound quality, IMO. Basically a receiver is everything shoved into one enclosure, but you don't need all that stuff for true 2-channel (or 2.1, like I have. Even I get flack for buying a preamp that a subwoofer output, as it adds processing circuitry). I never believed preamps/amp combos sounded better than high end receivers until I actually compared. The different was not subtle. The sound stage grew a lot wider, gaining depth along with width. And imaging - wow...big difference! Imaging went from reserved and unimpressive to pinpoint and precise. Sometimes I think my rears speakers are on, but they aren't. Anyway, YMMV, but definitely listen to both and compare. I was a skeptic, but I sure am glad I tried it out. That might be the route I go. Seems like it would basically be a stand alone 2 channel set up, with the ability for 5.1 when needed. Never really thought about a system set up like that.
Well, I think I'm going to increase my budget again. These are some of the amps I'm looking at. Anyone have any experience with these or comments? I think I'll push my budget to $1500-$2000.Parasound Halo A212 - Emotiva XPA - 1 (possibly overkill, maybe an xpa-2 instead)AVA Insight 440
If you want to push your budget some more there are a set of Opera Callas mini's on Audiogon. I think the seller's price is high, so you may be able to get him down some. These are some of the best monitors I've ever heard.
Quote from: coke on 22 Oct 2009, 01:00 amQuote from: Nuance on 22 Oct 2009, 12:54 amQuote from: coke on 21 Oct 2009, 10:44 pmWhat is the advantage of that over using the preamp outputs of a high end receiver out to an amp to power the mains?In short, sound quality; better sound quality. It's subjective so you'd have to try it yourself (by listening), but separates sound better than receivers. There is no decoding or processing circuitry. With separates you have individual/separate power supplies, thus less heat. Separate enclosures also isolate the low-level audio signals of the tuner and preamp from the large magnetic fields of the power amp (got that tidbit from an A/V mag). All of these contribute to better sound quality, IMO. Basically a receiver is everything shoved into one enclosure, but you don't need all that stuff for true 2-channel (or 2.1, like I have. Even I get flack for buying a preamp that a subwoofer output, as it adds processing circuitry). I never believed preamps/amp combos sounded better than high end receivers until I actually compared. The different was not subtle. The sound stage grew a lot wider, gaining depth along with width. And imaging - wow...big difference! Imaging went from reserved and unimpressive to pinpoint and precise. Sometimes I think my rears speakers are on, but they aren't. Anyway, YMMV, but definitely listen to both and compare. I was a skeptic, but I sure am glad I tried it out. That might be the route I go. Seems like it would basically be a stand alone 2 channel set up, with the ability for 5.1 when needed. Never really thought about a system set up like that. Correct. Just be sure the HT Bypass is included, because then you just run cables from the preamp to the receiver's preouts, and you're good to go. But until then you can just enjoy music.P.S. The Parasound P7 and 2100 have subwoofer outputs...for guys like me who need to place the subwoofer somewhere else other than the speakers due to poor in-room bass response where the speakers sit. Like I said before, best of both worlds.
I've been considering my options, and I think i want to get a preamp and DAC, but those will be my last pieces to add.This is also a home theater, so I don't want to lose my 5.1 if possible.Speaker + receiver + amp first. Use receivers preamp out for amp. Use my old speakers for center and surround.Add SubReplace center and surrounds with Salk.Last stage - Add preamp with HT bypass, and a DACThanks for the help, and any comments on this are appreciated.
lol, you almost sound as bad as I am. My dad's nickname for me is "upgrade". I'm always replacing something between my computer, car stereo, and home stereo.your post also reminded me that i'm probably going to sell my PS3 and replace it with an Oppo. The ps3 is just too noisy when listening to music at low volume.
What's the benifit of that over an ipod? I'm not familiar with those. I have a 160 GB ipod and use lossless + an ipod dock to RCA cable.
What's the benifit of that over an ipod? I'm not familiar with those.I have a 160 GB ipod and use lossless + an ipod dock to RCA cable.
