0 Members and 1 Guest are viewing this topic. Read 29722 times.
When the seagull calls on a song I have my dog thinks it is a bird and barks at my HT2s alot. He also looks around for Norah Jones when she is on. I dont know if it is someone in the room singing to you as you hear it, but it is really funny. Also sounds really good.
Well, a lot of speakers are going to sound good on Norah Jones. This has always been a sore spot for me. The first cut on Jim's HT4 demo is some young lady singing about In the Arms of the Angels way too close to the mic. I've A-B'd that with just about every speaker I have here, and she always sounds about the same. There just isn't enough complexity in the overtone structure to differentiate between good speakers and very good speakers. And then there's that Bird on a Wire thing (don't get me started). You need much more complex music than that to sort out differences among decent speakers. I use classical orchestral music, but I'm sure there are more contemporary cuts that will do as well (and have probably been listed in the demo CD's thread). Yup--another late night post. But if I hear One More Norah Jones Demo----,,,,,,,,,. Sorry. I've been to a lot of audio shows.
Well, a lot of speakers are going to sound good on Norah Jones. This has always been a sore spot for me. But if I hear One More Norah Jones Demo----,,,,,,,,,. Sorry. I've been to a lot of audio shows.
Quote from: DMurphy on 21 Oct 2009, 02:45 amWell, a lot of speakers are going to sound good on Norah Jones. This has always been a sore spot for me. But if I hear One More Norah Jones Demo----,,,,,,,,,. Sorry. I've been to a lot of audio shows. Time for you to start buying music from adydula's Outstanding Demo CD's list..... and then perhaps start giving them away. After all, making CD copies isn't that expensive...
Sounds like you really love your Dyn's, coke. I don't blame you. Try to score an audition of the HT2 TL, and bring your Dyn's along. That will be the true tell.
I already have them sold, so it's just a matter of finding a replacement now.
As far as mids and highs, i really enjoy them, but I can't stand the bass. I've become aware of it now, and it's impossible to overlook.
Quote from: coke on 21 Oct 2009, 12:21 pmI already have them sold, so it's just a matter of finding a replacement now. What a fantastic position to be in! You have a good pair of speakers (great speakers to some) that you'll pass on, however until you find your next pair you will have the ability to compare the Dyns to those that you audition. Its a great learning opportunity.If I may, you should also consider treating your room. Acoustic panels transformed my attic into a listening room.Kirk
Super fun, Coke. I would recommend broadband acoustic treatments too, not just thick curtains which are narrowband (high end). As far as speakers from Jim - I would listen to the HT2-TL. Based on your comments I think they will impress you the most. I have the HT2's, non-tl, and they are fantastic with that magic mid-range and amazing clarity. John
I have 20 of these in my "theater" http://www.walmart.com/catalog/product.do?product_id=10098005I've considered additional treatment, but i'm going to wait until I get new speakers. I think my next thing to do would be work on the ceilings. The walls in the room are 9' i think, at the point where the vaulted ceiling starts. I think the ceiling extends to around 15'. I'm not sure how much of an impact they have on sound.
Quote from: coke on 21 Oct 2009, 03:21 pmI have 20 of these in my "theater" http://www.walmart.com/catalog/product.do?product_id=10098005I've considered additional treatment, but i'm going to wait until I get new speakers. I think my next thing to do would be work on the ceilings. The walls in the room are 9' i think, at the point where the vaulted ceiling starts. I think the ceiling extends to around 15'. I'm not sure how much of an impact they have on sound.Those aren't thick enough, nor made of the proper material to do much. No offense or anything. If you want to fix the room you need to measure it, then use panels with a good amount of density that are at least 2" thick. Treating the first reflections points will help a lot, and installing bass traps will help alleviate that "boom" that you had. Also, adding a subwoofer would take away the boom and give you more headroom down low, as it can be placed in the ideal location in-room. I love my SongTower RT's, but there is only so much 5" drivers can do. Crossing over to dual subwoofers made a large difference, and it allowed me to EQ below the Schroeder Frequency (200Hz). Adding room treatments as of recent (thanks to kshep) helped EQ from about 140-800Hz. My bass response and lower midrange is a quite a bit better now, so I highly recommend trying some of these things. If you don't you might just find that any speaker you place in that room has the same issues. You mentioned it was a theater. Is that where you had the Dyns? If so, I assume you already have a subwoofer(s)?
The curtains provided a realitively low cost option. I couldn't find anyting else that cheap. I'm going to build a large sub(s) to replace it.
Quote from: coke on 21 Oct 2009, 04:20 pmThe curtains provided a realitively low cost option. I couldn't find anyting else that cheap. I'm going to build a large sub(s) to replace it.Some of us are able to work with our hands a little and it sounds like you may enjoy it too. I enjoy building stuff. As Nuance shared we found a great source for diy acoustic panel building. And if you can build a sub you can build an acoustic panel. They cost about $20 each. The panels are great for first reflection points. I am not an acoustic specialist, there is a thread on this site you may visit and get professional input.Check out this site: http://www.atsacoustics.com/cat--DIY-Acoustic-Materials--102.htmlAs you noticed there are a bunch of guys expressing their input, please know that I (we) are here to help and share our experience, in the end you will do what is best for you and makes you happy.Kirk
