I use the Knosti Disco Antistat Vinyl Record Cleaning Machine Cleaner Kit.it does the job but i would like to get the Project Vacuum cleaning machine. However the Knosti makes a big difference to most records.it comes with a stand for drying that holds 15 lps i have another stand on the way that hots 20 allowing me to clean more at the same time. however i know people like to clean records in many different ways so i guess it is what works for them. I would like to know how you clean your Vinyl.
I finally put together an ultrasonic cleaner, and then use a Nitty Gritty vacuum to remove the liquid. I've found this to be, by far, the best way to get your vinyl as clean as possible. I'll never go back to a just a wet brush or even a wet vacuum. Here in the States, we can put together an ultrasonic cleaner for under $200, using a Chinese ultrasonic vat and a slow rpm motor. Looks good i would like a ultrasonic cleaner. Maybe one day soon i have been looking this one ebay $469.90 Aud i think given Australian prices its not too badBelow is my current very manual system
