Omega Mikro 900-Watt power cables, sold sold sold
0 Members and 1 Guest are viewing this topic. Read 798 times.
mikeg1
« on: 17 Oct 2009, 03:23 pm »
Omega Mikro 900-Watt power cord for sale. Original owner and about one year old. This cord replaced the Wireworld Gold Electra 5 squared (a little more transparent for half the price).  $395 plus shipping for each cable. These are $1003 each retail. Pls check my agon feedback under mikeg.  These have the latest network boxes.
From the OM website:
900-Watt Active
The 900-Watt Active power sounds best five feet long. If you can?t make a five-foot power cord work in your installation longer lengths are available as custom orders.
The 900-watt rating is conservative and represents the limit on continuous average power. Short peak demands, of the duration of loud musical peaks, up to 3000 watts can be safely handled.
The 900-Watt power cord uses pure copper ribbons with optimized geometry and processing protocols to transfer power between the source of power and your components. Each ribbon is insulated using the same multi-polymer film used in our interconnects. We designed our AC plug to sound better than anything else we could find, including hospital-grade plugs and other such devices that use unnecessarily large amounts of bad sounding dielectrics.
Our silver-plated fine copper braid on the outside shields and protects without adding more dielectric. Our IEC socket uses minimal dielectric and compression connections instead of solder. The compression fittings float in their compartments so that they?re loosely coupled to the polymer dielectric and are mostly surrounded by air.
This combination of features assures that our power cords achieve the same high standards of time domain fidelity as our interconnects. Our 100-Watt Active Power Cord will make your low power components sound better than you?ve ever heard them. The 900W version is best suited for higher power applications like amplifiers with the same attributes as the 100W.
Our active power cords are identical to their passive counterparts except they use a 9-volt bias voltage from a battery and network supply box. The bias applied to the shield further reduces the residual smearing effects from our already minimal multi-polymer dielectric. With the reduction of smearing, the impact on the sound is immediately obvious; micro dynamics and transients are reproduced with greater clarity, backgrounds become blacker and more solid. Leading and trailing edges are more like live and have an excitement and presence you must hear to believe.
The battery/network box is finely crafted from bird?s eye or curly maple, which further contributes to clean sound and looks great too.
« Last Edit: 18 Jul 2011, 10:51 am by mikeg1 »
mikeg1
Omega Mikro Blue 900-Watt power cables, 2 power cables
« Reply #1 on: 11 Jul 2011, 07:10 am »
Bump
