GOOD GOD SOMEONE HELP ME!
0 Members and 1 Guest are viewing this topic. Read 5963 times.
BobC
Re: GOOD GOD SOMEONE HELP ME!
« Reply #20 on: 19 Oct 2009, 02:29 pm »
I don't think audio equipment should be this complicated.
I agree with that...but consider all the work that goes into music servers and vinyl....nothing is as easy as it should be.  "Easy" is to use a receiver and be done...adding an external amp is easy enough,  adding a pre with HT bypass adds to the compexity, trying to share a sub (my case) further adds to the complexity.
Good luck with your quest.
Bigfish
« Reply #21 on: 19 Oct 2009, 09:25 pm »
My father is an electrician, and we have run seperate lines for my audio equipment; I would bet on it not being a house electrical system issue.
Would it be possible that when you ran the dedicated lines the new wires crossed some older house wiring?  If so is it possible that the new wires are possibly contacting the old wires?  You need to trace the dedicated lines to make certain your dedicated audio wires are not contacting any old wiring.  At any point you find the wires touching or close to contact I recommend you separate the wires with a block of wood or something non-conductive.  Also be certain that your new dedicated audio wires are not twisted.  Unfortunately, most electrical stuff would work fine with a ground loop but it will kill us Audio Phools!
Good Luck,
Ken
sts9fan
« Reply #22 on: 19 Oct 2009, 10:54 pm »
So you have lifted the earth on the pre with a cheater?  Why would you think it's the amps if it worked before and the pre is used?
Nicholas Bedworth
  • That's me, the one with the glasses...
    • DigitalDirect Website and demo
« Reply #23 on: 20 Oct 2009, 07:54 am »
Sounds like the ground shield on one of your interconnect cables or jacks is failing mechanically. Could be there's a strain relief problem when the cabling is attached to the unit. Are the interconnect or speaker cables particularly heavy or otherwise straining the terminal posts or receptable?
My guess is that it's something mechanical. After all, if your father's an electrician, it's unlikely that hot and neutral have been switched at the outlet. Still worth double-checking.
Say, have a friend connect up everything, under your guidance. Watch them do it. Does one of the connectors "give" a bit, or require a lot of force to connect the cable?
The shock you're receiving could be leakage current, low voltage but enough current (milliamperes is enough) to give you quite a surprise. Regular electrician type equipment may not be adequate for this task.
Could also be that the chassis of one of the components in your system is "floating" way above ground. You should be able to measure this voltage, relative to ground.
Another idea: the case of output transistors is often "live". Could one of them be shorted against a heat sink?
When you send the gear back to Klaus, be sure to include the power and interconnect cables.
