0 Members and 1 Guest are viewing this topic. Read 7306 times.
Curly Woods: I use Janszen Superior-Z caps throughout the crossover, plus mundorf and mills resistors, and Janszen air-cores with the exception of an Erse Super-Q steel laminate in series with the woofer. Internal wiring is Supra.
http://www.silcom.com/~aludwig/images/diffdem.gifThe above animation illustrates whats going on with diffraction. Some people say addressing the problem affects / attenuates the FR by as much as 1.5 db.
In the meantime I constructed an impedance flattening circuit from some parts I had on hand that should smooth out a broad impedance bump centered around 1khz.
Quote from: EthanH on 16 Oct 2009, 07:51 pm In the meantime I constructed an impedance flattening circuit from some parts I had on hand that should smooth out a broad impedance bump centered around 1khz. Oooooooooh great idea! Do let us know how that goes.Yo Jim, does the fact that the tweeters have hex grills and are set in a mirror imaged configuration make a big difference when it comes to using diffractionbegones?
