9B fuse issue
0 Members and 1 Guest are viewing this topic. Read 2894 times.
nae
9B fuse issue
« on: 14 Oct 2009, 04:59 pm »
Hello
I use the Bryston 9b-st and it had down 3 times when I started the power.
The fuse was blew and the inner fuse is 250V F2A, I using 4 Ohm speaker.
What's the standard fuse spec? 2A or not...?
I take it to fix and the fixer suggest to change fuse to 3A.
Is it a good solution?
My english is not so good and hope you can understand.
Thanks.
srb
Re: 9B fuse issue
« Reply #1 on: 14 Oct 2009, 06:17 pm »
Looking at the 9B ST schematic, it specifies 2AG-2A fuses.
http://bryston.com/BrystonSite05/pdfs/21206/9BSchematics_May98Oct99.pdf
Give James Tanner some time to see this post, and he or his technical crew will have some more information for you.  I would only use 3A fuses if the Bryston service department directed you to.
KeithA
Re: 9B fuse issue
« Reply #2 on: 14 Oct 2009, 08:40 pm »
Hmmm.....
The latest revision (I think) (page 2 of the pdf) on the Bryston site seems to have 3A fuses :scratch:
As well, the first post relates to a Euro version (240 v), so that could make a difference. This is a query for Mike & James for sure.
Keith
srb
Re: 9B fuse issue
« Reply #3 on: 14 Oct 2009, 08:54 pm »
Oops!  :oops:   Didn't make it to page 2!
Yes, what I said and what he (Keith) said:  Don't do anything with those fuses until you TALK TO BRYSTON!
nae
Re: 9B fuse issue
« Reply #4 on: 14 Oct 2009, 11:11 pm »
I am in Taiwan and use 110v.
Thanks for all and i will wait the bryston information.
srb
Re: 9B fuse issue
« Reply #5 on: 15 Oct 2009, 09:34 pm »
Hear anything yet?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 9B fuse issue
« Reply #6 on: 15 Oct 2009, 10:13 pm »
I spoke to engineering and they said do not use anything over 2 amps as it is there to protect the rest of the circuitry.
james
joe
Re: 9B fuse issue
« Reply #7 on: 16 Oct 2009, 06:26 am »
I will suggest you don't use any electronic whose power is above than 2 amperes.
nae
Re: 9B fuse issue
« Reply #8 on: 16 Oct 2009, 01:45 pm »
I got it and will follow it.
Thanks for your important information.
