V2 ---> V3 and "the better one is the enemy of the good"
0 Members and 1 Guest are viewing this topic. Read 17799 times.
neutralos
Like an old german wisdom says: "the better one is the enemy of the good"
And this should not mean, that the V2 was an amp of average quality  -
Edit: 07. January 2011
My views about Nuforce overall sound performance changed meanwhile. The IA-7 V3 is not so good as I described it in the past. It was clear beaten by an stronger Tripath regarding tonality and details. The bass performance maybe just plays only a rule in case of very hard to drive speakers.
Don't know how the performance of the ref. series is.
« Last Edit: 7 Jan 2011, 12:19 pm by neutralos »
Welborne
  • I love open baffle with 100db sensitivity!
Re: V2 ---> V3 and "the better one is the enemy of the good"
« Reply #1 on: 14 Oct 2009, 05:04 pm »
guess what my friend, i just sent my ia-7 v2 to the agent here in Hong Kong for upgrade and they will return it to me next week. I can't to wait to hear the new version. i will report more here. :drool:
beachbum
  • Vinyl Delivers all of the Music
« Reply #2 on: 14 Oct 2009, 05:36 pm »
neutralos thanks for your comments on what your are hearing with V 3. The price for V 3 is very reasonable and i m ready to get it on my SE V2s. Let us know as you get more hrs on your amps any new impressions.
neutralos
« Reply #3 on: 17 Oct 2009, 10:51 am »
... of course there are also some critics even though they are less and to handle good with
corresponding equipment.
Valid for both - V1 and V2:
- depending on the recording quality of some CD?s I can listen out a microfon sibilance.
But this can be depended on my audio configuration consisting of a Meridian CD Player and a pair of very dynamic 20 yrs old Focal Expression speakers. The kevlar tweeter is well known for it?s great dynamic and resolution.
I haven?t tested much cables or an AC filter yet. These are the ways to go for fine-tuning next time.
Welborne
« Reply #4 on: 18 Oct 2009, 05:15 am »
One question. I think this is the Ia-7 fitted with V3 board, but it occurs to me too that the power supply and preamp section boards are also layed out differently. The output inductors are now located on the board instead of near the speake socket ends etc.
So when IA--7 v2 is taken in to upgrade to V3, is it the case that the power supply board/preamp boards are to be changed too?
This is V2 internal
nuforce-casey
« Reply #5 on: 18 Oct 2009, 05:40 am »
Hi,
No this is a IA7V2, the preamp board has been changed so the assembly is more logical and to accommodate new 1-piece chassis.  It's a layout/format change but the circuit remains the same.
V3 is hard to tell from a picture like this, the most important difference is that there is a 'sense wire' on each of the speaker cable, so you'll see a thick speaker cable and a thin 'sense wire' both connected to the binding post.
Welborne
« Reply #6 on: 18 Oct 2009, 06:01 am »
hi casey,
thanks for the input. so you mean the image on the top and bottom are BOTH V2?
neutralos
« Reply #7 on: 18 Oct 2009, 08:44 am »
hi casey,
Hi Welborne,
don?t ask too much !!! :D Let the cooks do their job and enjoy the meal  :thumb:
Dapo
« Reply #8 on: 18 Oct 2009, 07:54 pm »
hi casey,
I think the picture on the top is V3. Where did you find this picture?
Welborne
« Reply #9 on: 18 Oct 2009, 08:33 pm »
hi casey,
i got it form some chinese review website. It was talking about V2 IA-7 but I thought it looks different from what is installed in my own IA-7 v2
Dapo
« Reply #10 on: 18 Oct 2009, 09:37 pm »
This is the picture of new V3 board from Nuforce site. Very, very similar, but this is not the same board like one from the top. When you look further there is some modification on V3 board.
Borad from chinese review website is some kind of hibrid V2 and V3!!?? :scratch:
rustydoglim
    • www.nuprimeaudio.com
« Reply #11 on: 20 Oct 2009, 07:05 am »
Both the IA-7 images are showing V2 boards.
All the V3 boards should have the model # "Nuforce R5".
IA-7 use a shorter version of this board (since input section parts were moved to the preamp board).
In future production, we will change the board color to black.
Valid V3 boards:
Red color board with "Nuforce R5" label
Black color board (next production run) - hey just applying the black dye to the PCB, don't freak out, no change in the design.
Mass. Wine Guy
« Reply #12 on: 8 Mar 2011, 10:34 pm »
Pardon my fuzziness, but do you mean v2 is better than v3 or the other way around?
rustydoglim
« Reply #13 on: 22 Mar 2011, 09:39 am »
V3 is our 3rd generation amp and it is better in every way than V2. There are many reviews on our website and also measurement on the upgrade/technology section.
Mass. Wine Guy
« Reply #14 on: 22 Mar 2011, 11:46 am »
Looks like there is a decided difference of opinion on this point. How large is the power supply and what's the damping factor?
neutralos
« Reply #15 on: 27 Mar 2011, 01:35 pm »
Hi,
as I said before: I just only can talk about the I-A7 V3 and I owned it with the I-A7 V2 together at same time.
I am just sure that I was more influenced by expectations about the V3.
Jason & Team offer a very professional support. No doubt. How the Ref. Monoblocks do sound combined with different Pre Amps I cannot tell.
Tubo
« Reply #16 on: 8 May 2011, 01:53 am »
Clear as mud. Reminds me of ancient Greek oracles whose forecasts were so  ambiguous people would hear what they wanted to hear.
