need help finding tubes for my guitar amp
0 Members and 1 Guest are viewing this topic. Read 3446 times.
vpolineni
« on: 7 Jan 2004, 12:52 am »
I have an ampeg reverberocket amp that has recently died.. i believe it needs to be retubed..
here are the tubes it needs:
Two Groove Tube 6L6s and three 12AX7s
here's a picture:
[/img]
where can I buy tubes for it? any help would be appreciated. thanks.
Bwanagreg
« Reply #1 on: 7 Jan 2004, 02:05 am »
Shouldn't be hard to find. Try
www.musiciansfriend.com
Search on "6l6 tube" and lots of Groove Tubes come up.
Cens
« Reply #2 on: 7 Jan 2004, 02:14 am »
Here's another site: http://www.thetubestore.com/tubesbytype.html
Chris
vpolineni
« Reply #3 on: 7 Jan 2004, 02:27 am »
thanks chris and greg.. that's just what i needed.
eico1
« Reply #4 on: 7 Jan 2004, 02:48 am »
I'd take it to be serviced, tubes don't usually just die without smoke and fire.
Some spares are usually good to have around to try swapping, you can get some good used ones from Jim McShane if you want to get your feet wet.
http://pages.prodigy.net/jimmcshane/
steve
