AKSA 55, but which one??
DaveC
« on: 13 Oct 2009, 10:15 pm »
Hi All,
I have been keen for a while to get a feel for the sound of the Aspen amps.  A little while ago an AKSA 55 came up on Fleabay, and it went for a figure I couldn't resist.  I'll be trying it with my rebuilt Quad 57's, so I'll have to be gentle.
It looks like it was professionally built, albeit in a cheap crappy chassis.  It is configured with dual 160VA toroidals, but only cheap Jaycar MT2114 ones - not sure whether there is any value in changing them for better ones.
More interestingly, I expected that it would be the basic boards, but having received it I am not so sure.  There are a number of Blackgates on the boards, which makes we wonder if the boards are Nirvana or even N+ spec.  How can you tell what boards they are?
On each board there are 3 x Black Gate BG-NX Hi-Q, one 50V 100mcF Blackgate standard , and there are three regular Rubycon electrolytics (63V 120mcF if my memory serves me well).  Power supply caps are Nippon Chemi-Con if that is any help.
Additionally, it came with no documentation at all.  Does anyone have a copy of the build manual/instructions they could send me?
Thanks in advance,
Dave
Melbourne, Australia
AKSA
    • http://www.aksaonline.com
Re: AKSA 55, but which one??
« Reply #1 on: 13 Oct 2009, 10:22 pm »
Dave,
Why on earth don't you ring me, or drop me an email?
I'm quite happy to oblige you for the cost of printing, which is minimal.
I would say it's a stock AKSA which has been pirate 'upgraded'.  It should have different caps in the power supply if it were an N or N+.
How do you like it?
Hugh
DaveC
« Reply #2 on: 13 Oct 2009, 11:01 pm »
Wow, that was quick!
Thanks Hugh - I'll follow up off-line.
I haven?t listened to the amp you ? I wanted to check the bias before firing it up.  I don?t want to fry either it or my Quads, and since I know nothing of its history I plan on being cautious.
Certainly looking forward to getting it running.
Dave
