FLAC & Squeezebox Novice Questions
0 Members and 1 Guest are viewing this topic. Read 7098 times.
adydula
Re: FLAC & Squeezebox Novice Questions
« Reply #20 on: 17 Oct 2009, 10:34 pm »
Ok,
I have preorderd the Touch!
I have been using dbpoweramp and have ripped 57+ cds so far and its 16.6 GB storage using the default compression with FLAC.
This is really not a issue like I thought it might be using a lossless codec.
This is great! I will copy the entire library to at least 4 drives for safety in case a drive fails.
The touch according to Logitech is due out in late DEC.
Amazon is taking pre-orders....USB and a 24/96 dac!
Alex
firedog
« Reply #21 on: 18 Oct 2009, 03:17 pm »
My answer for you is that you can't know if an external DAC will sound better than your OPPO without trying one. I do know that my 2 external DACs (MF DACv3 and TACT ) give better sound than the output from a Duet.
There are some good, relatively inexpensive DACs coming on the market now. The new Musical Fidelity v-DAC goes for $300 and has gotten great reviews:
 http://www.avguide.com/blog/the-little-dac-could
There are other contenders in this price range. See if a dealer will let you give one a trial. Or buy a DAC used on audiogon.
srb
« Reply #22 on: 18 Oct 2009, 03:47 pm »
Since no one has the new Touch yet, we'll have to see, but perhaps the new DAC and circuitry will take it up a notch above the current models (in sound quality, apart from the new 24/96 spec).
I looked on both Logitech and Amazon sites, but did not see any availability date.  Were you given an expected availability date upon ordering?
adydula
« Reply #23 on: 18 Oct 2009, 05:48 pm »
Hello,
No date listed on Amazon. I called Logitech they said late December.
As far as how good this dac will sound we will see in late December! aa
I have seen a few posts stating that external dacs all sound different...and some that say they bought a $599 dac and its sounds "better' but not $599 better!  :duh:
Anyhow I will try this and compare to the Oppo CD analog  and the Onkyo 805 dacs and then maybe try out a few external to see for myself if its worth going down that route.
All the best
Alex
adydula
« Reply #24 on: 21 Oct 2009, 12:15 am »
Update, I got a reply to my question:
Will the new Touch allow for both a USB drive attached at the same time its conencted to a network via wireless or ethernet.
The reply was YES!
hmmmm
Alex
 aa
