Doug,Many thanks. Whenever I ask for advice on these things, I can ALWAYS rely on you to come up with great suggestions. If I haven't mentioned it before, I really appreciate it.The good thing about Adcom amps is that they seem to be readily available. I'll keep my eye out for this one. Just as a matter of interest, do you recommend this one specifically because it has four channels of amplification? I'm wondering whether I gain very much using one channel for each of the subs when there's only two channels of music, and little stereo information below 100Hz in most recordings. I had presumed I'd be better off with a more powerful 2 channel amp and then daisy-chaining the subwoofers together. But I'm open to all suggestions.I should check what the impedance of the subs is. I'm not sure if they're 4 or 8 ohms.Chad
