Speaker selection advise
0 Members and 1 Guest are viewing this topic. Read 18520 times.
genjamon
Re: Speaker selection advise
« Reply #40 on: 21 Oct 2009, 08:35 pm »
Umm, I'd go down to $500 shipped for these....
http://www.audiocircle.com/index.php?topic=62338.0
ltr317
« Reply #41 on: 22 Oct 2009, 12:19 am »
t,
I'm not sure about the AE P4 driven by the 2 watt Miniwatt.   According to the AE pamphlet, the P4 is 88 db and recommended power is 10-125 watts per channel.  If you don't have a big demo room and don't need to play loud then maybe the Miniwatt might do.
Paul
« Last Edit: 22 Oct 2009, 01:49 am by ltr317 »
t-head
  • 'I am sure that I am sure of nothing'
« Reply #42 on: 22 Oct 2009, 02:54 pm »
ltr317,
Thanks. I considered the P4s on the recommendation of Ken at ALO. I asked about the miniwatts ability to drive the JB3s. His reply was that the P4 were a better choice...I looked into the Hsu monitors due to their 92db efficiency, though it was measured in half space so some say more like 90db...still looking. Trying to run 2 watts into small speakers may be untenable, though small space/near field will be where I will be using them.
Richard (t)
