0 Members and 1 Guest are viewing this topic. Read 108480 times.
Well that would work for me, but obviously won't satisfy the crowd that feels you need a $500 USB cable in the mix. Steve
It would be interesting to compare 1. Plugging the HiFace directly into the computer and using a BNC coaxial cable to a DAC with a BNC input versus 2. Connecting the HiFace directly to the BNC input on a DAC and using a USB cable to connect to the computer.
Steve's question is interesting. The HiFace could be connected directly to the BNC input of a DAC using a BNC female-BNC female adapter, and a female to male USB cable could be connected to the computer.Would this be a better option than a BNC-terminated coax cable connecting a BNC-equipped HiFace to a BNC-equipped DAC?I guess the question is what carries audio better, 75ohm coax cable or USB cable. Hypothetically, the cable is 15'.
I received a HiFace USB adapter with a BNC connector today, and the clicks are pretty bad. I sent an email to M2Tech, but I suspect the HiFace is going back. I am running Mac OS 10.6.2.
I too had too many "pops" even with Snow Leopard. I guess they still haven't perfected their MAC drivers.
The clicks on the Mac are a serious issue. M2Tech wrote to me in January to tell me that they were aware of the problem and were working on a fix.
