0 Members and 1 Guest are viewing this topic. Read 108334 times.
If you like this improvement, the sonic upgrade from the modified Hiface is a major leap. Sorry, I just couldn't help myself
I know that RCA's are not 75 ohm, I was just hoping that it might be a better quality adaptorAccording to the hub instructions if the blue led light came on, then it was switched to external power.re attentuators, I would need to use 2 RCA to BNC adaptors then as I don't have BNC's on either the HiFace or the Havana.To be honest, I'm pretty happy with how the 1.5m GH spdif cable sounds and am more concerned about the possibility that I may have a HiFace that was manufactured with different clocks than the original...TBD...see this thread: http://www.head-fi.org/forum/thread/503323/hiface-sensitive-information
so RCA hiface -> RCA to BNC cable -> BNC attenuator -> BNC to RCA adaptor -> DAC ?I'm wondering if all the extra connections would only increase the reflections I'm trying to avoid?
I will shortly order Keny's mk2 but in the mean time i am still listening to my trusty "old" Wayne modded SB3. I suppose the attenuators will work for it (any other s/pdif out?) too as i use only the digital out of the SB3 into my Dac ( DEQX)?
I just ordered wanted to order ( minicircuits) 3 attenuators.6,10 and 15dB en that was around $35 but canceled as shipping was betwee $79 (by boat) and $100 for expediting or express!! A bubble envelope would do. A blu-ray disk out of US is 10 dollars shipping!!==========HA I fjust found out I can buy them in Holland in several shops....45-50€ a piece, appr. 60-70 US $ a piece
Yes they will but I believe the attenuators will more than compensate!
