0 Members and 1 Guest are viewing this topic. Read 108333 times.
Do you know if the Hub is actually providing external power to the USB - what is the quality of this power? You really need to answer these questions before you can evaluate.RCA connectors are NOT 75 ohm & can never be!To use an attenuator buy a RCA to BNC adaptor!
I know that RCA's are not 75 ohm, I was just hoping that it might be a better quality adaptorAccording to the hub instructions if the blue led light came on, then it was switched to external power.re attentuators, I would need to use 2 RCA to BNC adaptors then as I don't have BNC's on either the HiFace or the Havana.
To be honest, I'm pretty happy with how the 1.5m GH spdif cable sounds and am more concerned about the possibility that I may have a HiFace that was manufactured with different clocks than the original...TBD...see this thread: http://www.head-fi.org/forum/thread/503323/hiface-sensitive-information
You only need one
Well, I have gone ahead and purchased a Boxed HiFace with the modded 3.3v and internal battery power supply from John Kenny. I have heard wonderful things in regards to John's mods to the HiFace and since I have committed myself to this direction, I contacted John and should have my HiFace by the end of next week.
I have yet to settle on the DAC to replace my modded Zhalou 2.0 DAC, which is absolutely no slouch with the mods I have done to it. I've looked and read about the EE, Neko, W4S and of course DIY DACS such as the Buffalo II and the ACKODAC. I am leaning towards the Buffalo II as it is much less money than the ACKO and I could come in at just around a grand if I add Paul Hynes regs. I am waiting on Acko to get back to me with prices on all the modules needed for a fully functioning DAC. I will also be buying some attenuators both 6 and 10 db.Yours,Randy
I normally play audio with an Maudio 24/96 Audiophile, connected to a NOS DAC, playing only 44.1 files, sounds wonderfull!A friend gave me his Hiface to try but I cannot get it working properly?I installed it on my audiopc and it gives a distorted sound. As my audiopc has a tweaked Windows XP I installed XP-SP3 from scratch with all the options but still: the sound is scrambled/distorted.I have 2 audiopc's and both give the same results!Playing the Hiface on my EEEpc with XP works like a charm, just installing the driver, connect to the same DAC, no problems whatsoever?I use the 103141 driver (latest) on XP-SP3 32bit. Does the driver have dependancies I am not aware of (like ".NET") or am I missing something else?
Hello Ed,So far I have not listened to the real difference as I was trying to solve the problem I have. This evening a friend of mine is coming over and we will try and make a comparison between the EEEpc/HiFace and the Maudio.I think the Maudio is a very nice card, "musical" is a better word! The HiFace will have to work hard I think. I will post results as soon as I have them.Regards,Kees
Let us know what processor is being used in the PC you are trying that is not working correctly. There seems to be issues with AMD processors, certain USB controllers and the HiFace. I am using the HiFace with both an Intel Atom on my EeePC Netbook and my Core2 Duo laptop running XP SP3 or Win7. I am using either the Kernel Streaming mode or the WASAPI interface with Foobar2000 v 1.03 with great results.Another thing to check is that the USB port is really a USB2 port.Just some thoughts.
Ed,They sound the same to me. I switch between KS and WASAPI modes depending on the material. So far I think WASAPI on Win7 sounds great with the HiFace. Just to be clear, I use batteries to power the HiFace, so no dependence on either of the PC's USB2 power supplies.
Last night I got a bit of a result with the HiFace that I would like to share:It looks as if the HiFace hates chipsets from VIA and/or indeed AMD. My CPU is an older AMD Thunderbird 3000+ and my mainboard has a VIA chipset.I disabled the onboard USB and installed an ALI USB PCI card and hey presto: the HiFace works! Connecting a wireless keyboard and mouse to the same USB card is impossible though. If mouse/keyboard is connected the HiFace plays the music at a higher speed (??, sounds like pitch-control) with crackles and clicks. If I remove keybord/mouse while playing music the sound goes back to normal within 5 seconds.Today I will connect a normal keyboard and mouse so that I can listen to some music and compare with my Maudio.
