0 Members and 1 Guest are viewing this topic. Read 108334 times.
Just had a chance for a quick listen, but a -6db attenuator on each end is sounding good.
Is a 6dB at each end of the cable better sounding than if both 6dB are put at one end?
Oh, and he showed us some scope shots, and between his battery power supply for it and the attenuator, it was MUCH cleaner from a squarewave/overshoot/ringing standpoint. It's always nice when the data matches the listening impressions.
I ordered two BNC 6db attenuators, I'll see how it goes.
Well, I think I have found a setup that gives the same effect, but is easier to implement.I have the RCA version HiFace conneced directly to the DAC with an RCA(m) to RCA(m) adaptor from Radio Shack. I used a 15' USB cable and it sounds as good as the BNC setup with the 10dB pad. This is with my DAC, so not sure how this will react with other systems.The second stage is a powered two port USB hub that I will run off a regulated battery supply. This should do a nice job of isolating the PC power noise and put the power right at the HiFace.Will get the connectors at Radio Shack tomorrow to start the project. I already have the USB cable, battery and 5VDC regulator.
It is running with the regulated battery DC supply and the powered USB hub!Will listen over the next few days and compare to the HiFace with the BNC/Attenuator setup.
Looks like Mapleshade is offering a hiFace in a maple enclosure for $189.
