0 Members and 1 Guest are viewing this topic. Read 30925 times.
Quote from: bmckenney on 16 Oct 2009, 02:47 amI'm assuming the bags are seriously flawed bass traps, or maybe not seriously but partially.Bryan has the right answer. Bags of insulation work well, at least if they're large enough and you have enough of them.--Ethan
How do the bags of insulation perform in comparison to a 16"-24" ID, 1" thick, 6' tall DIY tube-type pipe insulation traps?
Quote from: oneinthepipe on 16 Oct 2009, 09:06 pmHow do the bags of insulation perform in comparison to a 16"-24" ID, 1" thick, 6' tall DIY tube-type pipe insulation traps? This question seems to be the core of the debate between using a hollow, "sealed" tube, and fully packed tube, of the same size (and safe to assume tri-corner placement?) -Tony
Quote from: TRADERXFAN on 17 Oct 2009, 01:29 pmQuote from: oneinthepipe on 16 Oct 2009, 09:06 pmHow do the bags of insulation perform in comparison to a 16"-24" ID, 1" thick, 6' tall DIY tube-type pipe insulation traps? This question seems to be the core of the debate between using a hollow, "sealed" tube, and fully packed tube, of the same size (and safe to assume tri-corner placement?) -TonyExcept that the bags of insulation do not have the 1" thick rigid fiberglass pipe insulation surrounding them, whether or not the pipe insulation tubes would be filled. I plan to leave the tubes sealed and unfilled in my 1st attempt.
But the bags are insulation just like the pipes. I'd say they are the equivalent of pipe insulation filled and capped and the foil backing paper removed. Density might be slightly different but I can't imagine it's something that anyone can actually hear...
Hi bmckenney,Quote from: bmckenney on 17 Oct 2009, 02:09 pmBut the bags are insulation just like the pipes. I'd say they are the equivalent of pipe insulation filled and capped and the foil backing paper removed. Density might be slightly different but I can't imagine it's something that anyone can actually hear...Actually, they're not the same at all. The sealed tubes create a resistance to the wave as the wave penetrates the wall. Once inside, the resistance changes (drops) radically. This is part of how these work.(More information can be found at the ASC links Tony provided.)As always, I would suggest comparing the two to hear this for yourself.Best regards,Barrywww.soundkeeperrecordings.comwww.barrydiamentaudio.com
It looks like you're in the camp of using tubes instead panels. Is that true?...
