Oublie,isn't there a major design fault in your project?For a cross over at 2.5-3 kHz the centers of the drivers involved should be less apart than 1/2 wavelength of the xover frequency: about 6 cm. This applies for the horizontal distance even more than for the vertical. IMHO you need to place the tweeter line almost immediately next to the wharfedales. Placing two wharfedale lines as wide apart as shown in your EDGE simulation also calls for disaster. Try to simulate for 45deg to get the picture.
True, Comb Filtering could be a big issue ... i'll try a bit of remodelling and see how i get on maybe MMT is a better option.
If your goal is to build a dipole the baffle should not be curved.
(Edge) diffraction does not exist, in the conventional sense, with a dipole design.
I suggest you read all you can at the Linkwitz site - http://linkwitzlab.com
Hi Oublie,Sounds like any advice I might have is clearly superfluous (or wrong!).David
