0 Members and 1 Guest are viewing this topic. Read 8513 times.
$5000 for a receiver? No offense, but he might as well just pop the extra grand or so and get the Arcam D2v.
Quote from: Nuance on 7 Oct 2009, 05:19 am$5000 for a receiver? No offense, but he might as well just pop the extra grand or so and get the Arcam D2v. I am currently driving 2 Ht3 the Arcam 600 and there is plenty of ood power for concert level listening in a room larger than the OP has listed. The 2nd option you listed above must be the Anthem D2v but theprice points I have seen on that piece with powr is way more than the rcam. I also understand that the D2v has Hdmi issues as does the Arcam with certain STB's.Thank you very muchFury
Either would do the job, but I don't see a processor like the Anthem DV2 that alone costs $6K as being part of this equation.
It's been a while since I have read about Seaton but wouldn't the catalyst put him around 10k just for speakers? I also like the suggestion about the Submersive, from checking the specs a while back those things look amazing. I really like arcam stuff but I think 5k for an AVR is a little crazy, the connections are just going to get outdated in a few years anyway, but you cant go wrong with Arcam, at least the few pieces I have heard by them.
Quote from: srb on 8 Oct 2009, 12:40 amEither would do the job, but I don't see a processor like the Anthem DV2 that alone costs $6K as being part of this equation.And a $5000 receiver is? Separates have better sound quality in my experience, hence the recommendation. YMMV Either way you look at it, to get amazing sound quality and to fulfill the OP's requests there are only a few pieces that are capable.To prevent getting ganged up on further, I'll change my recommendation to the Parasound P7. It's much cheaper, can be used for multi-channel music and has HT bypass. Now grab a great receiver (doesn't have to cost $5000) and you've got great SQ for music and movies. Yes, you'll have two pieces and a few extra cables, but you'll achieve the best of both worlds.
Isn't the P7 a preamp? With no HDMI inputs? That costs 2K?I don't think that would meet the OP's needs very well since he specified a setup that's video-capable.
I like the idea of a high-quality lower cost receiver coupled with a powerful amp(s) (like the Emotiva).
Quote from: modode on 8 Oct 2009, 01:45 amIsn't the P7 a preamp? With no HDMI inputs? That costs 2K?I don't think that would meet the OP's needs very well since he specified a setup that's video-capable.^ Hence the idea of also getting a receiver for strictly home theater. Like I said, best of both worlds (One for only 2-channel and multi-channel music that has a bypass for HT, and one for only movies). And all coming in at much less than the prices mentioned already. Did you miss that part of my post? For those who don't know, a HT bypass allows the preamp to be connected to the receiver, thus allowing the amplifiers that power the speakers to be run using the receiver when the preamp is in "bypass" mode or turned off. It's a highly convenient feature and comes in handy for those who cannot afford an Arcam receiver or Anthem D2v. You should read up on it before you tell me it won't meet the OP's needs (which it does, of course). Quote from: modode on 8 Oct 2009, 01:45 amI like the idea of a high-quality lower cost receiver coupled with a powerful amp(s) (like the Emotiva).So do I, hence my above recommendation for both. The HT bypass connection will allow each to be used separately, but still allow the amplifiers to work with each individual component.
Nuance, I'd normally agree with you that separates offer better performance, and I'm no fan of HT receivers, especially for music listening (Quite the reverse in fact.)But in the case of Arcam AVR600 I'd have to say that this receiver offers truly exceptional performance for the $$ that has been previosly available only with separates costing much more.I am a high end audiophile (20+ years in the hobby and a 16k 2 channel set up) who's extremely picky about sound. I don't own the 600, but I did get to audition it a couple times, and I was frankly surprised by how good it sounds- it's an outstanding piece in every way. And the amp section is way more powerful than its conservative ratings might lead you to believe. Having had an Arcam AVR300 for HT, I would say the brand is an easy rec for someone building a music suround/HT system how really cares about music. BTW, have you actually heard the Arcam yourself?If music listening as well as movies is a priority, I'd frankly go simple with the Arcam or separates with Cary gear. Although they are one of the most respected high end audio manufacturers, Cary's a bit underrated in the HT theater community - however they produce outstanding gear for both music and HT .
I just said if he's going to spend $5000 why not spend $6000 on the D2v?
The true recomendation should be to give Jim a call!
