GR Research AV-1's for $340.00 Pr ( SOLD )
0 Members and 1 Guest are viewing this topic. Read 5578 times.
Ron
« on: 5 Oct 2009, 11:13 am »
I have for sale a beautiful pair of GR Research AV-1 Mini Monitors in new condition finished in natural cherry. Latest revision with the GR-T3 tweeter and parallel crossover networks using Alpha Core inductors and Erse Caps bypassed with  Sonicaps.  These speakers have a very clean, open,and natural sound quality with excellent imaging and depth. Voice reproduction is very natural sounding on both male and female voices. Bass response is very clean and well defined to around 55 hz. Selling the pair for $370.00 plus shipping cost.
« Last Edit: 3 Feb 2010, 11:55 am by Ron »
Ron
Re: GR Research AV-1's for $370.00 Pr
« Reply #1 on: 25 Oct 2009, 12:10 am »
 Updated to show better pictures of the AV-1's.
Rocket
« Reply #2 on: 25 Oct 2009, 01:22 am »
Hi Ron,
Great looking pair of speakers.  I'd buy them but shipping to Australia is a deal killer.  The fit and finish of these speakers commands a higher price.  I wish you luck with the sale.
Regards
Rod
Ron
« Reply #3 on: 25 Oct 2009, 11:59 am »
Hi Rod,
 Thanks for the compliment about my AV-1's. I was very  pleased with how well they turned out not only in appearance but sound quality too. They are very nice sounding speakers on all types of music, but especially on vocals. To me,they sound almost as good as the Neo 2X which I have built a number of pairs recently for other people.Unfortunately,you are right that shipping cost to Australia would be very expensive.
 Thanks again for your interest and comments.
Ron
Ron
« Reply #4 on: 6 Dec 2009, 11:35 pm »
 Price reduced to $340.00 + shipping cost for the pair. Would make a nice Christmas present.
roymail
  • Roy in TX
Re: GR Research AV-1's for $340.00 Pr
« Reply #5 on: 14 Dec 2009, 04:11 am »
Can I ask what's a good power match for these speakers as well as the Neo 2X model?
Looks like you build some very nice cabs.
Thanks.
Ron
« Reply #6 on: 14 Dec 2009, 12:20 pm »
  I would would recommend a minimum of about 50 watts per channel for both the AV-1's and the Neo-2X's. Most high current, low distortion amps should work just fine. Also, your power requirements depend on the size of your listening room and how loud you like to listen. Presently I am using a Parasound HCA 1000A power amp which has a power output of approximately 120 watts per channel into an 8 ohm load. Tube type amps also work very well with both the AV-1 and Neo 2X. If you plan on using a receiver, most of the popular high quality,high current models like Onkyo and Denon work very well.
starkiller
« Reply #7 on: 26 Jan 2010, 09:48 pm »
How about placement from the rear wall??
Ron
« Reply #8 on: 26 Jan 2010, 11:00 pm »
 Being a rear vented type of speaker, they need to be at least 2 feet away from the back wall.
starkiller
« Reply #9 on: 26 Jan 2010, 11:04 pm »
Dang, at best i could go half a foot :(
cujobob
« Reply #10 on: 26 Jan 2010, 11:25 pm »
You can plug the ports, but it decreases bass response.
starkiller
« Reply #11 on: 26 Jan 2010, 11:57 pm »
have a good sub so not worried about bass, but how about imaging that close to the wall?
cujobob
« Reply #12 on: 27 Jan 2010, 12:02 am »
Being that close to a wall will make any speaker's imaging suffer.  However, Danny does an excellent job of designing speakers with excellent on and off-axis response which makes for great imaging.
These speakers are really hard to beat at that price.
starkiller
« Reply #13 on: 27 Jan 2010, 12:18 am »
will be using a 50wpc tube amp....is it enough??
Meicheng
« Reply #14 on: 27 Jan 2010, 05:09 am »
I would think a 50 watt tube amp would be plenty good enough power-wise.
Ron
« Reply #15 on: 27 Jan 2010, 10:17 am »
 Cujobob is correct that the rear port can be plugged which would allow you to place it closer to the rear wall. Since you will be using a subwoofer, it should work just fine. I have some foam plugs that could be used with the AV-1's.
starkiller
« Reply #16 on: 28 Jan 2010, 12:44 am »
do these have the no-rez??
Meicheng
« Reply #17 on: 28 Jan 2010, 01:02 am »
If I didn't have a pair of Paradox 1, I would be all over these.  I think Danny's speakers are just fantastic for the price.
starkiller
« Reply #18 on: 28 Jan 2010, 01:07 am »
I know I know  :|  I just have x amount of $ that has to be used for speakers and for stands and other misc things. With no job for over a year funds are very tight.
Ron
« Reply #19 on: 3 Feb 2010, 11:54 am »
 Thanks Martin!  Hope you enjoy them.
Ron
