0 Members and 1 Guest are viewing this topic. Read 7468 times.
I bought the perf metal for the top of my amps at a local Metal Supermarket store and they just cut it to size on a really big shear and/or brake to bend it. If you have one available near you that might be a good option.
Depends...Is the screen like the material in your windows?Or is it a heavier gauge material with a more "open" mesh (like chicken wire)?Sandwiching, and clamping the screen between two layers of something like plywood and using metal sheers (tin snips) would provide a nice straight edge and keep the screen from stretching. However, any screen that I can think of would need to have it's edges covered so there's no danger of cutting somebody.Or...Using the same sandwich technique, you could use a high RPM carbon based cutoff wheel mounted in a cordless drill.Bob
