Y adapter and VDA 2
0 Members and 1 Guest are viewing this topic. Read 2563 times.
gcos
Y adapter and VDA 2
« on: 24 Sep 2009, 01:51 am »
I would like to use two sources into the coaxial input of my VDA... would a simple RCA Y adapter work ?
CIAudio
Re: Y adapter and VDA 2
« Reply #1 on: 24 Sep 2009, 09:30 pm »
no, you would need something that actually switches between the two sources.
gcos
« Reply #2 on: 24 Sep 2009, 10:19 pm »
Thanks but only one source will be on at any one time...would you still need a switch ??
With so many digital sources being used today I hope CI would look at providing more input options on later models of the VDA or perhaps a switch ??
CIAudio
« Reply #3 on: 25 Sep 2009, 06:24 pm »
It will not work properly because of impedance mismatch caused by both devices in parallel.
srb
« Reply #4 on: 25 Sep 2009, 06:42 pm »
A popular S/PDIF switcher is the USA made Inday DA4X-R Remote Controlled Switcher
http://www.inday.com/da4x/da4x.htm
gcos
« Reply #5 on: 25 Sep 2009, 06:58 pm »
thanks guys....I will get the Inday unit..looks like the real deal..
