cables
Derockster
cables
« on: 23 Sep 2009, 08:11 pm »
Hi guys,I've received my TVC only two days ago and I'm already loving it.What cables are you guys using going from your source into your TVC and out from your TVC to your amps.
milpai
    • My Dedicated Audio Room
Re: cables
« Reply #1 on: 23 Sep 2009, 08:46 pm »
I use Signal Cable's Silver Resolution.
Brown
Re: cables
« Reply #2 on: 24 Sep 2009, 01:28 pm »
Whatever you desire, copper, silver etc.  Its all about synergy.  Stay under 2 Mtrs if you can. I am aware that this TVC can handle up to 5 Mtrs, however my experience was the shorter the better. Low capacitance cable seem to match the TVC.
   If you can make your own contact Nick and find out what wire he is using internally. use the same wire.
