Hum from i82
0 Members and 1 Guest are viewing this topic. Read 4925 times.
reikso2h
Hum from i82
« on: 20 Sep 2009, 08:53 pm »
Hello,
I've been noticing more hum than usual coming from my i82 going into some BiBs with Fostex FE-126s. I was wondering if other i82 owners have noticed fairly significant hum from theirs, and if they have any tips to reduce it.
I am not using any power conditioning, so I realize that dirty power my be an issue. Any recommendations for cheap power conditioning?
Thanks.
-Mark
nature boy
Re: Hum from i82
« Reply #1 on: 20 Sep 2009, 09:18 pm »
You might want to post a WTB ad for a Felix balanced power conditioner.  Several AC'ers have built these over the last couple years.  This is a DIY item, so make sure to get some pictures and make sure the unit has a DC blocker incorporated.
Cheers and good luck
NB
Audiovista
Re: Hum from i82
« Reply #2 on: 21 Sep 2009, 01:09 am »
Hi Mark,
How long do you have your i82 and did it hum from the start?
Boris
reikso2h
Re: Hum from i82
« Reply #3 on: 23 Sep 2009, 12:05 am »
It's coming up on 2 years now.
it's always had some hum
i don't know if it's increased, but i'm noticing it more now with the high efficiency speakers (94-95dB)
Audiovista
Re: Hum from i82
« Reply #4 on: 24 Sep 2009, 01:26 am »
Hmmm... some hum is normal, with high eff speakers should not be problematic at 3-5ft distance. If it is, perhaps something changed...
