Where can I get WE 310A 's?
0 Members and 1 Guest are viewing this topic. Read 4060 times.
zygadr
« on: 14 Sep 2009, 07:00 am »
Anyone know if this top cap valve can be bought from a supplier anywhere?.......on this planet :duh:????
ginger
Re: Where can I get WE 310A 's?
« Reply #1 on: 15 Sep 2009, 04:01 am »
Evatco in Australia have them.
http://evatco.com.au/webcat1p6.htm
They look fairly pricey thou'
Outside of the US WE used to license others to build their tubes, most notably STC. They would distinguish their parts by putting a 4 in front so an STC 4310A is the same as a a WE310A. You might find STC 4310A are cheaper.
I have 5 off STC 4311B Pentodes sitting on the shelf for a "maybe one day" project.
Ian
zygadr
« Reply #2 on: 16 Sep 2009, 04:06 am »
 :D Thanks Ginger. I have ordered from them before, but must have missed the ''4'' prefix you mention. :duh:
zygadr
« Reply #3 on: 27 Sep 2009, 01:19 pm »
O.K ..........EVATCO have confirmed that they have stock .
Are the STC 4310A  EXACTLY the same spec. wise and gain wise as the WE 310A?
