Bent Audio NOH Wiring
Doc Jr 8156
« on: 10 Sep 2009, 01:01 am »
Hello John,
I cant find my diagram on how to wire my NOH with "gain".  Is the wiring diagram for the old NOH available anywhere?  Thanks.  Godspeed.
John Revilla
John Chapman
    • http://www.bentaudio.com
Re: Bent Audio NOH Wiring
« Reply #1 on: 10 Sep 2009, 02:47 am »
Hello!
I did purge my 'system' of S&B info a while back. Kind of a cleansing of sorts...... I can dig a drawing up and e-mail to you.  Just e-mail me with details of your build so I can choose a drawing to match as close as possible with what you have now.
Thansk!
John
Doc Jr 8156
« Reply #2 on: 10 Sep 2009, 04:02 am »
Thanks a lot John.  Mine have 3 pairs of inputs and 2 pairs of output. All RCAs. No XLR.  Seiden switches, S&B MKIII. Godspeed.
John Revilla
John Chapman
« Reply #3 on: 10 Sep 2009, 01:43 pm »
Hello!
Thanks for the info. If you just want to wire for +6db full time then do this:
Right now -- and + will be connected together. Break that connection and wire the -- wire to the input ground where the - wire is attached now at the neg side of the input switch. Then connect + where the ++ wire connects now at the positive side of the input switch.  This will flip you to +6 mode.
If you need a switch then pop me a mail with a ship to address and I can shoot you down a couple switches and a sketch of hook-up.
Thansk!
John
Doc Jr 8156
« Reply #4 on: 10 Sep 2009, 07:50 pm »
Thanks John.  I think I understood what you meant.  I'll try it tonight and post again if I'll encounter problems.  Godspeed.
John Revilla
