0 Members and 1 Guest are viewing this topic. Read 31686 times.
I have a pair of these on my desktop and they do sound great. Only problem is when I try and listen at low levels I only get sound through one speaker
[A] This is a common property of speakers using dual-analog style amplifiers...
Thanks for this info. I was about to order a pair of A5s, but I definitely don't want issues at low volume.
Don't make this issue bigger than it is! These speakers are incredible...
Don't make this issue bigger than it is! These speakers are incredible, and this issue is a single spot on the dial. if you raise the volume even one iota it goes away (or conversely lower the pc/source volume). The speakers are more valuable than this issue.
.... Also, they may go well with my 10 wpc integrated amp
Curious why you would want to use an integrated amp with a powered speaker system?cheers, ed
