PromitheusUSB
0 Members and 1 Guest are viewing this topic. Read 1715 times.
Dexsam
PromitheusUSB
« on: 5 Sep 2009, 09:49 am »
Hi,
I am using the PromitheusDAC for over a year now with good results and is happy with it.  BTW I have the 2 op amps replaced with Bursons discrete opamps and have separate psu for the Bursons.
With the growing use of PC/hard disc storage of digital music, I am looking at the PromitheusUSB option.  Please someone correct me, if I purchase the Promitheus USB, I can:-
1) Play music on PC on audio system if the PC is connected to the DAC via the Promitheus USB?  Just plug and play?  If possible, I intend to place the USB board inside the DAC since I have an input selector switch on the DAC.  Will it work on any media player including itunes?
2) Does it work if I plug my ipod/iphone directly to the Promitheus USB?  If it works, I can always power the pcb from elsewhere instead of drawing power from the ipod.
Thanks in advance.
