0 Members and 1 Guest are viewing this topic. Read 9460 times.
Seriously, the only way to relieve doubt is to try it for yourself. Textbooks will not give you the true answer.
Quote from: BobM on 28 Sep 2009, 05:17 pmSeriously, the only way to relieve doubt is to try it for yourself. Textbooks will not give you the true answer. I wouldn't have a clue as where to start. I do know that PC's can be very expensive. I use an Oppo 980 as a CD player. Maybe a top notch PC won't do it any good. Cheers Charlie
Therefore, the need for a technical explanation is academic.
