Is my sub busted?
0 Members and 1 Guest are viewing this topic. Read 2608 times.
sts9fan
Is my sub busted?
« on: 2 Sep 2009, 11:42 pm »
When I turn up the stereo to what I would call "medium high" the sub starts makin a mechanical "thuawacking" sound.  I do not think it should be too loud as I think I read Danny say it has pretty high output.  It's the servo 12 in the sealed box offered a bit ago as a package.
kris
Danny Richie
Re: Is my sub busted?
« Reply #1 on: 3 Sep 2009, 02:07 am »
Yeah it shouldn't be doing that. Is the driver reaching its X-max and bottoming out or is it something else?
sts9fan
« Reply #2 on: 3 Sep 2009, 01:05 pm »
How would I figure that out?  It does look like it is moving a ton.  What does bottoming out sound like?
Danny Richie
« Reply #3 on: 3 Sep 2009, 01:39 pm »
I don't know for sure as I have never bottomed one out.
That package deal came with the 300 watt amp so chances are less that you are overdriving it but it could be the case.
I'd back off on the volume setting a little bit.
sts9fan
« Reply #4 on: 3 Sep 2009, 02:27 pm »
I will but does not seem like it should be too loud.  I will take a measurment of when it happens.
cujobob
« Reply #5 on: 4 Sep 2009, 01:48 am »
Is the driver wired correctly?  I had an OB servo sub that went nutso because of miswiring.  Just a thought, though not likely.
zybar
« Reply #6 on: 4 Sep 2009, 01:50 am »
Same here.
Once wired correctly, no more thumping or whacking.
George
sts9fan
« Reply #7 on: 4 Sep 2009, 03:19 am »
Pretty sure it's cool.  Mainly cuz it just started to happen.
rythmik
    • Rythmik Audio
« Reply #8 on: 7 Sep 2009, 08:01 pm »
check if there is any air leak. Air leak can cause the air spring to be insufficient.  If the driver has been damaged, it generates a noise even when you just tape on the dust cover.
sts9fan
« Reply #9 on: 7 Sep 2009, 08:06 pm »
Will do.  Do you just feel for them or listen?
