0 Members and 1 Guest are viewing this topic. Read 10788 times.
Yep I decided to go with the 1.78:1. According to the manual the pj doesn't have enough zoom range to go from 2.35:1 all the way down to 1.78:1 at the same vertical height. Ive emailed dave (I think) @ carada and he suggest the 1.78:1 with the high contrast grey surface. Now I need a very long component cable cuz I think Id put my a/v rack at the front which is the most feasible place for my room not sure what length not till I get the pj and confirm the suitable throw dist. Any suggestions for decent cables? Monster is just too much.
Tell me something Im curious how did you all set-up your pj so that you get to use shorter cable runs to your source. In other words like placing your a/v racks. Behind listening area? On the side? PJ ceiling mount? In front? My HT room size is 16X12X9 ft. Any ideas? pls help master
Thanks for the input! This topic sure comes in handy just the rite time. I think I know hows it going to be but just to make sure I'll wait till I get the pj tomorrow so I know the exact throw thus the length of the cable needed. I forgot all about the ceiling mount Ive browse around and found one Chief RPA-225 for $168.80 anybody knows where else I can get a decent one for much less? I still dont have comp cables yet. BTW my pj is the panny L300U.
For a low level light, there is a nifty little night light at home despot which plugs into an outlet and has louvers over the bulb to direct the light to the floor. Something like 6 bucks for a pair.I'm just about to go with a z1 too. I've got a stack of dvds i which are waiting for the happy day it arrives...
I had the opportunity to see the Dwin,Seleco and Infocus 3 chip pj at CES. The last one I signed a aggrement to shut up but I can't stand watching anything else right now. I was amazed how well these pj's looked. I have a 7200 Infocus and I thought that was good. Enjoy what you have but in two years when these come down from the $20,000-30,000 price....I will be in line to get one.Larry
Mike--did you spend as much time as I did on the 'under $3500 projector' thread at avsforum?
