I have CK hubs
Lose 5 pounds. Think about it. How difficult is it to reduce your bike weight by 5 pounds vs losing 5 pounds yourself?
It seems like a good idea. However, if your bike loses 5 lbs. you will be able to use larger cogs which makes you go faster. Going faster will encourage you to loose 5 + pounds. A lighter bike is a more efficient bike and will give you handling advantage. That's how I look at it. Start with a lightweight frame and the rest will follow.
Found a practically new used set of wheels locally. Picking them up this weekend. Flow rims, hope pro 2 hubs, xt cassette, rotors already installed, and specialized tires - $250 for the set I plan to put some racing tires on these and run them tubeless for when the trails are smooth and i want more speed. These are nice since they already have the cassette and right size rotors, so it will be no problem at all to swap them out.Normal wheels are stans flows with dt240s front hub and dt350 rear hub. These are very nice, but I run heavy slime tubes and heavy tires with slow tread for most of the trails around here.
Good score! I think Levi paid more for his front brake.
