0 Members and 4 Guests are viewing this topic. Read 289569 times.
really? I can't see the smaller ring in that photo. The guide does look like a derailleur on second glance.39/26....guess that is a good compromise. Kindly like a compact I guess.
Yes. I changed the rear to a 10-speed cassette. Then I figured the rear derailleur has to be changed along with shifter, 10spd chain etc., etc. I could probably could have left the rear cassette alone but it just make sense to go SRAM XX all the way. It does worked together like music in harmony.
....Like what Phil mentioned, audio gears costs way more than bike parts.
Old one was 11-32 using short cage dérailleur.
I can tell you have some bucks into that bike. Are you running tubeless? That is another mod I am considering as my Bontrager wheels/tires are "tubeless ready".
New one is the sram xx 10-speed 11-36 cog.
SRAM is making some nice cassettes these days. I'm going to pick up a new one for my Road bike. The new Apex has a really wide range, something like 11-36 for a road cassette. They are sold out at the moment but for $60'ish, it's worth trying.
The MTB
Be aware that there are different types of "tubeless". The older, and still more common type of tubeless is "UST".Levi is running ZTR Crest rims which are a new style of tubeless tire system that is lighter than UST based wheels, though it requires a special sealant inside the tires once they are seated. Check out www.notubes.com for details on this system. It works amazingly well, though seating the tire the first time was a painful experience. I picked up a set of new wheels using the same ZTR Crest rims in February at the beginning of a mountain bike trip to Phoenix, and 2 days later nailed a cholla (cactus) pod dead-on. 2 minutes of work with the multitool to pull the dozens of spikes, and I was up and riding again - no air loss whatsoever. And the wheels are much lighter than my old ones. (Reducing rotational mass is a bigger benefit than reducing non-rotating mass.)
A 36 for a road cassette? I can't even imagine a need for that...
Looks great! Although isn't the seat a little low?
I'm with Phil. That saddle looks low. Did you take the picture before you adjusted it? If the saddle heigth fits you, your frame might be too large.
