Anyone Used Other Tubes in Tube Active Preamp?
0 Members and 1 Guest are viewing this topic. Read 1953 times.
RW35
« on: 18 Aug 2009, 04:41 pm »
Hello...
I tried 7308s but got buzzing and ocillation (they can't handle the higher current).
Does anyone know if a restistor mod is possible for heater current and if any other factors need consideration?
I find the 6N1Ps (tried various types, inc the rocket logo EBs) a little hollow in the mids, which makes music sound just a little distant and un-personal - does anyone else notice this?
I've tried 6BQ7As as these have similar heater current to 6N1P, they sounded pretty good, but I would like to hear it with 7308s
System: Pathos Endorphin CD, Silk TVC (volume pot), Promitheus Tube Active Line Amp, Revel B15 Subs X 2, ATC SCM50ASL Monitors
tanchiro58
Re: Anyone Used Other Tubes in Tube Active Preamp?
« Reply #1 on: 26 Aug 2009, 03:54 am »
Hello,
You should ask Nick about this. He would not hesitate to help you.
Here is the link for the tube replacement for your tube active preamp:
http://www.audiocircle.com/index.php?topic=67195.0
Good luck,
Tan
