Tempest
Lazz
Tempest
« on: 18 Aug 2009, 08:32 am »
Hi guys I need some advice.I want to build some open baffle dipole mains similar to the Jamo R909 in look and I was wondering if the Tempest X would be suitable as here in Australia we dont have a huge selection of woofers.Thx Lazz
dyohn
    • the12volt.com
Re: Tempest
« Reply #1 on: 18 Aug 2009, 05:56 pm »
Should work well.  I use a set of XJ-12's (early Shiva-X) in an open baffle and they are great.  You will need to ensure your subwoofer amp has a subsonic filter to protect the drivers from over-excursion.
Kevin Haskins
Re: Tempest
« Reply #2 on: 18 Aug 2009, 09:52 pm »
Yea... the Tempest will do fine in a dipole application.
