**ALL SOLD**Hafler SE240 amps - 120/175/350 watts - $140 each
0 Members and 1 Guest are viewing this topic. Read 6199 times.
Big Red Machine
SPECIFICATIONS
Power Rating:
Less than 0.025% total harmonic distortion at any
power level up to 120 watts continuous average power
per channel into 8 ohms at any frequency between 20
Hz and 20 kHz with both channels driven,
Continuous Power Output:
Into 4 ohms, below -04% THD, 20 Hz-20 kHz,
per channel: 175 watts
IM Distortion (IHF):
Less than 0.005% from 1 watt to 120 watts, each
channel, into 8 ohms.
Typical THD at $0 watts into 8 ohms:
20 Hz: 0.004%
1 kHz: 0.004%
20 kHz: 0.02%
Frequency Response into 8 ohms:
-3 dB, 2 Hz to 200 kHz at 1 watt.
+0 dB, -0.5 dB, 4 Hz to 40 kHz at 120 watts.
Typical Channel Separation:
20 Hz: 80 dB
1 kHz: 75 dB
20 kHz: 60 dB
Signal to Noise Ratio:
Exceeds 100 dB referred to 120 watts into 8 ohms.
Input Impedance:
47,000 ohms.
Input Sensitivity:
1.2 volts rms for 120 watts into 8 ohms.
Slew rate:
10 kHz, 60 volts peak to peak square wave: 45 v/us
Damping Factor:
300 to 1 kHz into 8 ohms.
200 to 10 kHz into 8 ohms.
Power consumption:
120 watts both channels into 8 ohms: 550 VA
Quiescent: 120 VA
Size:
5-1/4? high plus 1/2? feet, 17? wide. and 10-1/2? deep.
Net Weight:
27 Ibs.
Shipping Weight:
35 Ibs.
All specifications are subject to change without notice.
INTRODUCTION
The Hafler SE-240 is a two channel audio amplifier which
has been engineered to meet high performance and
reliability standards while maintaining affordability.
The amplifier employs a sonically proven circuit topology
driving MOSFET output devices. These devices provide
exceptional reliability as a result of their inherent rugged-
ness and resistance to abusive operating conditions. Con-
sequently, the SE-240 is capable of delivering high current
into low impedance loads, and generally the amplifier will
not be damaged in the case of an accidental short circuit
at the output. The drive circuitry is a high performance
arrangement with a double differential JFET input. Quality
components are used in the design to ensure longevity
and, above all, sonic excellence
Functions fine, some scratches.
UPS preferred. PP add 2.5% please. Double boxing.
« Last Edit: 10 Sep 2009, 02:58 pm by Big Red Machine »
Big Red Machine
Re: Hafler SE240 amp - 120/175/350 watts - $175
« Reply #1 on: 20 Aug 2009, 02:22 pm »
nice little amp
Big Red Machine
« Reply #2 on: 22 Aug 2009, 12:18 pm »
bump
Big Red Machine
« Reply #3 on: 25 Aug 2009, 11:43 am »
bump
Big Red Machine
« Reply #4 on: 25 Aug 2009, 01:07 pm »
I have 3 of these, if anyone wanted a pair of them I'd go $300 + fees for the pair.  Can be 350 watt monos or 120 wpc bi amp or for surrounds.  I'm moving over to some other Hafler amps for surrounds now so these need to move.
Big Red Machine
« Reply #5 on: 26 Aug 2009, 02:36 am »
Now on Ebay.
Big Red Machine
Re: Hafler SE240 amp - 120/175/350 watts - $150
« Reply #6 on: 26 Aug 2009, 12:24 pm »
$150 each
All 3 for $425 + ship
Big Red Machine
Re: 3 Hafler SE240 amps - 120/175/350 watts - $140 each
« Reply #7 on: 5 Sep 2009, 01:35 pm »
Lowered price, added photos of 2 more units:
chadh
« Reply #8 on: 5 Sep 2009, 02:05 pm »
Pete,
How old are these?  Are they likely to need new caps soon?
I'm going to need a decent, SS stereo amp to run my new Swarm subwoofer system, once I have an active crossover.  How do you think one of these would work for me?
Chad
Big Red Machine
« Reply #9 on: 5 Sep 2009, 02:36 pm »
Well in mono mode they can really crank at 350 watts output.  I picked these up not long ago.  Years ago I owned one and really liked it.  Can't say on the caps issue Chad, with any knowledge or experience.
starkiller
« Reply #10 on: 10 Sep 2009, 01:18 am »
any interest in a trade?
Big Red Machine
« Reply #11 on: 10 Sep 2009, 10:33 am »
Last one has 5 bids on Ebay and will sell this morning so I can't yank it from there at this point.
