Suggested setting for Phonomena II and AT 150 cart?
0 Members and 1 Guest are viewing this topic. Read 2058 times.
sanlanman
« on: 13 Aug 2009, 08:55 pm »
I have an AT 150 MLX cart in my Series 20, PA-1000 arm/PLC-590 table. I have a Phonomena II phono preamp on order and it has adjustable impedence settings. Can anyone on suggest some initial settings on the Phonomena II to start out with in combo with the AT 150MLX?
Wayner
Re: Suggested setting for Phonomena II and AT 150 cart?
« Reply #1 on: 13 Aug 2009, 09:13 pm »
I believe it will track very nicely at 1.5 grams.
It is rated @ the standard 47 K ohm impedance, so I would start there. It is the top of the line MM for AT. Should be a great cart.
Wayner  8)
