0 Members and 3 Guests are viewing this topic. Read 1213179 times.
Good stuff jeffac,only one question regarding the double corrugated, I was inder the possibly mistaken impression that the corrugations were perpendicular to each other, providing panel stiffening.Did I just totally miss something in my reading here? Could we possibly see the backside of your panels too?John
I think the idea of placing the panels between two sheets of plywood or mdf is a good one, but wax paper or something will need to be used to prevent adhesion to the mdf/ply, and the wax or waxpaper will have to be cleaned off the panels afterwards.
Polyethylene should work well. I don't know if many have access to large enough sheets.
only one question regarding the double corrugated, I was under the possibly mistaken impression that the corrugations were perpendicular to each other, providing panel stiffening.
o.k : ...............I give in..............gonna go to Pack and Send and get me some corrugated cardboard sheet
A question however, ..............how do you know if it's of superior quality?........is there an easy visual/mechanical way to check, or is it graded?
