Dan, Pretty much the same as the podium1 pictures. Same kind of spine and for his so called sound bridges I used the styrofoam backer rod. Helps take the weight of the panel off of the exciters and keeps the panel from pivoting as if the narrow line of exciters was a knife edge. So spiders are not stressed too much. My 1st panels have nothing holding the edges since there is no spine. My experience tells me that there is no penalty for restricting movement somewhat at the edges. Bass has not suffered.
I've had at least 3 instances of the tacky tape coming unglued from black gatorfoam over the past couple of days. I will monitor to see if there is a pattern, at which point I'll spring for the real 3M stuffI'm sorry you've had a bad experience with the Tacky Tape. Maybe the surface on the Gatorfoam just won't take to it like the paper surface of foam core.It was certainly not my intension to mislead anyone by my experience with Tacky Tape.Jack
It seems to me that the exciters should be placed in a straight line and as close together as possible for maximum treble response and deepest bass. Spacing the exciters out would seem to cause issues in both domains. Anyone tried this?Dan
Nice work doug s !!!!!!! ..........we have a true ''Podium clone''
Zobsky, I have had no problem with the 3M stuff letting go. I cleaned the plastic footers on the exciters and the areas of the panel that the tape contacts with 99% isopropanol alcohol 1st. I think that this is a necessary step. I guess that a glass cleaner would be OK too.
Quote from: zobsky on 1 Jan 2010, 05:51 amI've had at least 3 instances of the tacky tape coming unglued from black gatorfoam over the past couple of days. I will monitor to see if there is a pattern, at which point I'll spring for the real 3M stuffI'm sorry you've had a bad experience with the Tacky Tape. Maybe the surface on the Gatorfoam just won't take to it like the paper surface of foam core.It was certainly not my intension to mislead anyone by my experience with Tacky Tape.JackNo problem
