0 Members and 6 Guests are viewing this topic. Read 1213543 times.
aa...........O.K..............HERE WE GO...................the Re-board rep will visit me at work on a business and privateWhat's Re-Board?I couldn't Google it. Can I get it in the U.S.?Still using 20 X 30 inch foamboard, the highs are great and the lows into lower 30's.I have two prototypes, one set has one exciter with square corners. The second set has two exciters and rounded corners. The seconded set sounds much better, a fuller sound with lots of volume.Whether one exciter or two, the panels have a native resonance around 30 Hertz.I would think that a larger panel would lower resonance, adding more exciter will change things. With conventional dynamic drivers, the Fs can be lowered by adding weight to the cone.I have lots of exciters. Imagine having 16 or 32 exciters per panel? I don't know if it will play good, but it will play louder than I'll ever be able to stand.Jack
Gatorfoam is most likely better suited to much smaller panels only? Let's face it........Gatorfoam sounds great, but picking up a sheet that's 78inches by 28 inches by one end and levering it in to an upright position, watching it bend like a banana in the middle is asking for trouble........I should have known better ............it's just not rigid enough at that size.Maybe 10mm would have been better..........but I doubt it
Hello,I'm going to copy the podium system.So i need some information about the materials used in that setup.I know there is a honeycomb panel made of Nomex but i'm wondering about the thickness...then there is a mylar sandwich protecting the nomex honeycomb right?even here i wish to know the thickness of the mylar.I do not want to seem arrogant cause of this you guys are fantastic and you are working well, very well.I'm learning a lot from your mistakes and your successes, but I would overcome this stage and use the finest materials to get as close as possible to a hi-end results.many thanks to all p.s.clearly once assembled the panel, will explore the position of the exciters!
UPDATE :The Re-board rep. will be seeing me tomorrow, 9.15 am Perth time here at my office.As soon as the meeting, examination of the samples are over, I will report to this forum immediately on my findings and observations.
