Whyis it that so many conversations in audio these days are gravitating towards Bras and Pantyhose?
To get access to the DML skript you will need a NXT licence.
jeffacjust thought, this is a piezo oops , won't work probably very high resistance at low fr.bigger battery ?
There is Something I have been meaning to ask for some time now ,has anyone noticed that If you toe the panels inward ,sometimes quite heavily,[even tried facing the panels at each other] you seem to get an almost 3D effect .I am not sure If this is because of my long thin room or if it has the same effect in larger rooms ?It makes you feel like you can walk through the image, as if there is more depth.With the panels facing strait forwards they still sound good but it is more like a wall of sound [I think this is partly what I was hearing when I heard the podiums] which can sound a bit odd.I did not try this With the small panels, say down to A4 size ,as the panels seem to give good ambience already.This is also quite good for me as it makes the panels narrower and deeper ,so that I can have a bigger panel. On normal speakers toeing in seems to [IMO]give a more central image .If anyone can at sometime let me know if they can hear the same [or not ] It could be helpful , thanks.I could just be going mad [who said that]?
Can anyone comment on the sound of (say) two 2 x 3 panels vs one 2 x 6 panels on a single channel. I ask because it's going to be hard for me to acquire large pieces of gatorfoam. At least the smaller pieces can be shipped with no difficulty.
Quote from: zobsky on 11 Dec 2009, 03:50 amCan anyone comment on the sound of (say) two 2 x 3 panels vs one 2 x 6 panels on a single channel. I ask because it's going to be hard for me to acquire large pieces of gatorfoam. At least the smaller pieces can be shipped with no difficulty.[/b]My feeling is they would have to be seamed together in a way that would allow them to work as one large 2X6 panel. (Tricky)The bending waves need to expand across one large panel to radiate lower frequencies.Jack
If you can't get Gatorfoam, use corrugated cardboard.......it's better than nothing, or, trying to piece together smaller panels.
What If you cut a hole in the panel so that the lip of the back of the peizo can be glued to the front of the panel so that it is forward facing, this would make the peizo part of the front surface[nxt], radiating frequencies cleanly across the surface [no trying to penetrate through two surfaces and foam core ] ,hopefully this would sound cleaner from the front and louder .
