What made you choose to use elastic bands to suspend your panels while the bottom edges are sitting on cosmetic triangle sponges???If you liked the sound of your Mission X-space nxt panels why not try to mimic the designs of those panels first?
i hope to be clear, red is the 45X50x1 cm EPS panel, in violet the 90X50X1 cm EPS panel. the violet is my favourite
And this is measurement of Russian speaker:Impressive!
I would of used 2 part (5min.) epoxy adhesive instead of PVA glue....Even the type of adhesive can affect the sound.Annoying sound from the rear of the panels is due to the vents in that particular type of exciter...I prefer the exciters without vents.Tinny is mostly due to the type of material in your case XPS, which is the reason I prefer EPS for its warmer less tinny sound.One way to provide more focus is to use a frame for a more foward directional sound.When using a frame you must use some type of weather strip foam or rubber to attach the panel to the frame so that there wont be any distortion from two solid objects touching each other....I use frost king brand available at Home Depot.Not sure about how long for a exciter to break in but a brand new exciter is stiffer then one that has been used a while.
Here you can hear how it sounds in the recording https://youtu.be/j5ww2Fgd9D8https://youtu.be/2aXVxbXcS3w
Thanks for your input , much appreciated . I suspect that tinniness can be tamed , it's definitely the rear side combining with the front . I don't have many options for placement such as pulling the panels out from the walls so I've placed some open cell foam on the frame behind the driver , then draped some long haired wool over that which was better . I have a few sheets of Rockwool RWA45 , I'll cut out a piece , wrap it around (then clamp to the frame) and give that a try In terms of closed back exciters , what would you recommend ? Are the smaller sub 20w Tectonic Elements drivers worth looking into ? Much easier for me to obtain in the UK...cheersNic
It sounds good....What is the panel material they are using, Antinox?
honeycomb paper. There are some more records from Russia: https://youtu.be/7gAYd6sdox0https://youtu.be/VPew6zviYhY
