0 Members and 3 Guests are viewing this topic. Read 1214765 times.
jonners, I don't know about the accuracy of the specs on the 2 sites but I have found that cutting gatorfoam on a table saw works well. Nice clean cuts, very easy to work with.
donkaI am using el cheepo exciters from parts express .I am also using dcx and deq to only monitor the frequency responce, If I can make them sound good without the compensation this would be better.On 12x24 inch aprox 3 mm ply panel they reach 20k .They are good drivers at a bargain price.
jonnersIf you move down the page on that site, they tell you about panel materials to use
donkaDO your panels sound brighter [more hf ] from the back? I am wondering if the hf travels across the surface from the exciter ,but finds it hard to cross the foam to the front surface?
