0 Members and 7 Guests are viewing this topic. Read 1214714 times.
Alright - prepared another board and finally had a chance to listen to the Ultras and compare them to the Thrusters. My initial impression was better clarity at the expense of the bass. The boards were really large 2.5' x 5' at a 1/4 " thickness so it might have been too heavy for the Ultras (final boards will be smaller), but then on the other hand I have two subs in the room so the boards doesn't need to go down that low. More impressions to come later this week.
Can I get a Hellelujah!? I have seen the light my brethren and it is GOOD!Seriously though. I "finished" up one of my panels this morning. I did a quick wire up job and set it to rest on top of my sub. I hooked it up to the right main just so I could hear the difference between the old HTiB speakers and I was amazed! The panel itself looks like crap but it sounds extremely nice. I normally had to turn the avr to 30ish to get the sound out. With this thing I had it set on 13. I played a few movies just to see what I could hear. 1. Fast 6- When the cars are coming off of the elevator I could hear the individual pops of the exhaust. Like the car was driving in from stage right. 2. Act of Valor- When the River Rat comes in and unloads with the Dylan........WOOOOOOOWWWW! Before it was just a low rumble, now I can hear the gun spinning, the brass hitting the deck and when they open up with the other gun I swear I can hear the bolt cycling. In short, the clarity is astounding for movies, and this is just propped up against the wall with nothing insulating front the wall or sub. I was worried that they would not go low enough but the small non powered sub was easily enough to meet it. The wife walked in as I was testing and said the pnel sounded really good. Clearer than what we had and she was happy with what we had. The panel is 22x35.5 coated 1 time on each side it a 1:1 mixture of titebond3 and water. (I tried to color it with water soluble craft paint the Mrs. had lying around mixed in, don't do this, the paint left little chunks all over the panel which is why the panel looks like crap)The single XPS pink panther board more than overpowers the other speakers and now I am excited to fix up the others. Just a quick update to let yall know what I think. When I get the others done I'll post more!
Sounds like we have another believer joining the club!!! I had almost the exact same feeling myself when I first heard it properly mounted on a board, and actually still do evertime I turn it on. Update on the Ultras and the knocking. It looks like both Ultras I have do not have enough space between the magnet/mounting ring and legs. Not sure if this is an assembly error for the ones I have or if it is per the actual design. One of the exciters looks like it is slighly tilted in the way it is assembled - it is "sunken -in " more where the sticky stuff is.Anyways, as I mentiond before, if not playing them full-range or on lighter/smaller boards it will likely be OK (unless you have one "sunken-in" that makes the exciter not sitting straight in the plastic housing.) Tried to buy a thicker XPS board today, but they were out of stock. BTW: Had a thruster dead on arrival - the wire attaching the coil to the speaker tabs was broken-off. Hope to be able to return it.
Yeah... as much as I like the Thurster's bullet proof construction (steel spider and top quality construction) and they do sound notably better the Dayton Audio DAEX25FHE-4... but dang, I have to say that the Ultra's still have my complete love and attention on XPS. They do look cheap, are fragile but they sure do sound fantastic on XPS (and other lighter materials I'm sure).
Is this really the consensus? I'm shocked the puck design's sound quality is preferred over the DAEX25SHF-4 or the DAEX30HESF-4.I would be curious to know how the Elac driver (which JMC soundboard uses) sound in comparison... or the Visatons.
Hi all,new guy in town.I' m from Slovenia, currently staying in Indianapolis.English is not my first language so please,... I have been following this toppic for a long time and finally decided to participate in it.Recently I bought ten of DAEX30HESF-4 exciters. My plan was to use two of them for experimenting on different panels and then on a panel with best results put four exciters on each panel.But what I have found out...these exciters are loud!!!!Anybody has any experience with these exciters?Should I stay with one exciter per panel or should I go for four per panel.I'm afraid of losing heights due to the interference between exciters.Panels are made of CG...109cm x 65cm...golden cut.Experimental, not final product.
